DZONSS Ierakstīts Februāris 23, 2010 Share Ierakstīts Februāris 23, 2010 gribetu uzzinat vairak par so verki, apstajos uz ta jo ir iebuvets dekoderis Link to comment Share on other sites More sharing options...
janispauls Februāris 25, 2010 Share Februāris 25, 2010 (labots) Digiline7000 viņam nekā nav 1,kārtām atbalsta Labots Marts 4, 2010 - janispauls Link to comment Share on other sites More sharing options...
Valdis Marts 4, 2010 Share Marts 4, 2010 (labots) DIGILINE 7000 HD COMBO SAT+DVB-T ir jauns produkts. Parādījies pēdējo mēnešu laikā. Pats nopirku pirms nedēļas un esmu apmierināts! Cena LV apm. 140 - 190 LVL _________________________________________________________________________________________________ Identisku aparātu saraksts: Optibox Alligator ( http://www.optibox.c...?a=product&q=41 ), Skygate HD-PLUS ( http://prosto.co.il/...-plus&Itemid=86 ), GI ST9196, Evolution Infinity Plus, Next Ye-2000 DOBRATECH __________________________________________________________________________________________________________ Apraksts Main Processor: BROADCOM 7401 (300MHz MIPS32TM/16-e class CPU) Flash ROM: Default 32Mbytes DDR SDRAM: Default 256Mbytes 2 Slots For DVB Common Interface Standard 2 Smart Card Support 1 External eSATA Port 1 Set(3xRCA Vertical Array Type) 1 Set(3xRCA Vertical Array Type) 1 Optical(Fiber Optic Type) 1 Connector TV/VCR 2 USB A-Type Connector 1 Connector Ethernet RJ-45 10/100 Base-T 1 HDMI port HF IN – LOOP DVB-S2 Tunner ANT IN- LOOP DVB-T Tunner DVB-S/S2 Tuner And Channel RF Input Range: 950MHz ~ 2150MHz Input Connector: F-Type Female (With Loop-Through Output) Input Impedance: 75[Ohm] Input Dynamic Range: -65dBm ~ -25dBm Multi Demodulation Standard: DVB-S, DVB-S2 : QPSK, 8PSK Symbol Rate: DVB-S : QPSK Maximum 45Msps @ 2~45Msps DVB-S2 : 8PSK/QPSK Maximum 30Msps @ 10~30Msps Multi Decoding Method Standard: LDPC/BCH DVB-S2(1/2, 2/3, 3/4, 3/5, 4/5, 5/6, 8/9, 9/10) DVB-S/S2 MPEG TS A/V Decoding Transport Stream Format: MPEG-4 Part10 AVC/H.264 HD HP@L4.1 1920x1080@50Hz(ISO/IEC 13818 MPEG-2 TS Specifications) Profile Level: MPEG-2 MP@HL, MPEG-4 Part10 AVC/H.264 HD HP@L4.1 Input Rate: Maximum 90Mb/s Video Aspect Ratio: 4:3, Letter Box, 16:9, Pan & Scan Video Display Resolution: 1920x1080i, 1280x720p, 720x576i/p, 720x480i/p @ 50/60Hz Audio Decoding Format: Dolby Digital bit-streams, MPEG-1 Layer 1,2,3 Audio Output Mode: Mono, Left, Right, Stereo, Dolby Digital bit-streams(PCM 5.1 Channel, Stereo down-mixed Dolby ProLogic) DVB-T Tuner And Channel RF Input Range: VHF-High Band 149.5MHz ~ 426MHz, VHF-Low Band 50.5MHz ~ 142.5MHz, UHF-Band 434MHz ~ 858MHz Input/ Loop-Through Output Connector: 1 x Din Jack for DVB-T, 1x Din Jack for DVB-T Loop-Through Output (IEC 169-2 Female/Male) Input Impedance: 75[Ohms] Nominal Input Signal Level: -80dBm ~ -5dBm(64QAM, Code Rate 2/3, Guard Interval 1/32, Gaussian Channel) Digital Modulation Scheme: QPSK, 16-QAM, 64-QAM(Constellation) Guard Interval: 1/4, 1/8, 1/16 and 1/32 Modulation Mode: 2K, 4k, 8K modes Supporting System: DVB-T(COFDM) Compliant (Frequency Band Modulation) ETSI 300 744 IF BandWidth: 6/7/8MHz channel FEC Code Rates: 1/2, 2/3, 3/4, 5/6, 7/8 DVB-T MPEG TS A/V Decoding Transport Stream Format: MPEG-4 Part10 AVC/H.264 HD HP@L4.1 1920x1080@50/60Hz(MPEG-2 ISO/IEC 13818 Transport Stream Specification) Profile Level: MPEG-2 MP@HL, MPEG-4 Part10 AVC/H.264 HD HP@L4.1 Input Rate: Maximum 31.668450Mb/s, 27.709893Mb/s Video Aspect Ratio: 4:3, Letter Box, 16:9, Pan & Scan Video Display Resolution: 1920x1080i, 1280x720p, 720x576i/p, 720x480i/p @ 50/60Hz Audio Decoding Format: Dolby Digital bit-streams, MPEG-1 Layer 1,2,3 Audio Output Mode: Mono, Left, Right, Stereo, Dolby Digital bit-streams(PCM 5.1 Channel, Stereo down-mixed Dolby ProLogic) A/V And Data Output Analog Component YPbPr: 1 Set(3xRCA Vertical Array Type) CVBS(Composite Video), Stereo Audio: 1 Set(3xRCA Vertical Array Type) S/PDIF Dolby Digital Interface: 1 Optical(Fiber Optic Type) HDMI (with HDCP Option): 1 Connector SCART Interface: TV/VCR USB2.0 Host Interface: 2 USB A-Type Connector Ethernet: 1 Connector RJ-45 10/100 Base-T RS-232C Data Port D-Sub9 Interface: Transfer Rate 115,200bps(Firmware Upgrade Port) Conditional Access Interface PCMCIA: 2 Slots For DVB Common Interface Standard Smart Card: 2 Smart Card Support Storage Device SATA(Serial ATA): 1 External eSATA Port Power Supply Input Voltage: AC 100-240V ~ 50/60Hz Power Consumption: Maximum 35Watts Protection: Separate Internal Fuse Type: SMPS(Switching Mode Power Supply) Safety And EMI: For Country Regulation Physical Specification Dimension(WxDxH): 340x268x60[mm] Net Weight: About 3.0Kg Operation Temperature: 5°C ~ 50°C Storage Temperature: -40°C ~ 65°C Manuālis uz Optibox Alligator - http://files.inbox.lv/ticket/42bc3709bda69d047a1dfa0d64ea5dfbe2cc4600/MANUAL_Optibox+ALLIGATOR.pdf Labots Marts 5, 2010 - Valdis Link to comment Share on other sites More sharing options...
janispauls Marts 4, 2010 Share Marts 4, 2010 Identiski pēc skata,ne pēc iekšām Link to comment Share on other sites More sharing options...
Rudiger Marts 4, 2010 Share Marts 4, 2010 Varbūt sīkāk?Raksta, ka ar pēdējo softu 016.47 viss iet normāli, ražots esot Korejā?! Link to comment Share on other sites More sharing options...
Valdis Marts 4, 2010 Share Marts 4, 2010 Ar pēdējo softu griežas ok. Tas vairāk domāts medus tecinātājiem Man tagad atkal problēma ar Lattelecom viedkarti. Dēļ uzstādījumiem katru reizi slēdzot iekšā kartiņa jāpārsprauž, jo neatpazīst. Problēma secināta firmware VVEC016.47. Atliek gaidīt jaunāku versiju, kur kļūdas būs salabotas. Tagad jau esot kaut kur pieejama pat firmware VVEC016.67. Varbūt tur viss būs ok Links uz VVEC016.47 versiju - http://files.inbox.lv/ticket/de8e3aa935dc441fb41e0ca6d2b5a41ae2867de0/Digiline7000Hd-VVEC016.47.rar Link to comment Share on other sites More sharing options...
janispauls Marts 4, 2010 Share Marts 4, 2010 (labots) Pēc useru vārdiem itkā jaunā versija esot 86 http://westsat.com.u...hp?t=709&page=8 Labots Marts 23, 2010 - janispauls Link to comment Share on other sites More sharing options...
Valdis Marts 4, 2010 Share Marts 4, 2010 Diemžēl tur nav Paldies par to pašu Uz Optibox ALLIGATOR jau ir iznākusi VVPL016.82. Uz DigiLine 7000 klusums. Tuvākajās dienās meiģināšu nokoriģēt caur HEX editoru kādu vecāku Optibox softa versiju. Pa ''taisno'' lādējot neatpazīst Link to comment Share on other sites More sharing options...
Rudiger Marts 10, 2010 Share Marts 10, 2010 Šo varētu likt pie kurioziem, ja nebūtu tik skumji : можете подсказать где брать софт для Digiline 7000 HD ?- Пришлите мне номер чека по которому вы его купили у нас на мейл (order@xxxx.cc) и я отправлю вам софт!!! Link to comment Share on other sites More sharing options...
Valdis Marts 23, 2010 Share Marts 23, 2010 Links uz VVEC016.80 versiju - http://files.inbox.lv/ticket/e2b6814d88239df51b219af5d4ac8290e0e5a178/Digiline7000Hd-VVEC016.80.rar Links uz VVEC016.86 versiju - http://files.inbox.lv/ticket/80c0dbc9e6fab71113292d03e90162bbe81e0baa/Digiline7000Hd-VVEC016.86.rar Līdz 47. bija problēmas ar latviešu EPG. Tagad tam vajadzētu būt novērstam. Ja kāds notestē, tad uzrakstat atsauksmes. Šeit būs arī lietošanas instrukcija krievu valodā - http://files.inbox.lv/ticket/2ad688b2bd33aae31008d6ca194882661a06263d/Digiline7000rus.pdf Laba iespēja ir izmantot aparāta pulti, lai saprogrammētu tv pulti. Apraksts par procesu instrukcijas beigās Link to comment Share on other sites More sharing options...
ainars55 Marts 24, 2010 Share Marts 24, 2010 Paskaties te http://viasatfan.clan.su/forum/43-1129-1 Link to comment Share on other sites More sharing options...
Valdis Marts 31, 2010 Share Marts 31, 2010 Links uz VVEC018.01 versiju - http://files.inbox.lv/ticket/487413bd9ad1a816fb0a741ba221755038ab87de/Digiline7000Hd-VVEC018.01.rar LOADERim jauna versija. Mainās no 04.21 uz 04.26 Link to comment Share on other sites More sharing options...
Uldisra Aprīlis 19, 2010 Share Aprīlis 19, 2010 Kas ir ņēmies ar video ierakstīšanu vai var uzstādīt lai ieraksta .avi formātā vai ar kādu konverteri var avi failus dabūt. Kāpēc šis tuneris neredz avi failus. Vai vajag pāršūt jaunāko prošivku. Link to comment Share on other sites More sharing options...
janispauls Aprīlis 19, 2010 Share Aprīlis 19, 2010 Kādu formātu softā ielikuši iekšā pianisti ,tāda i būs Link to comment Share on other sites More sharing options...
mazais Jūnijs 5, 2010 Share Jūnijs 5, 2010 DigiLine 7000 HD - 19.63 Link to comment Share on other sites More sharing options...
janka78 Jūnijs 5, 2010 Share Jūnijs 5, 2010 Beidzot uz šīs softa versijas parādījās EPG programma Ltv1,Ltv7,Lnt,Tv3,Tv6 kanāliem virszemes tv. Link to comment Share on other sites More sharing options...
mazais Jūnijs 20, 2010 Share Jūnijs 20, 2010 (labots) DigiLine 7000 HD_19.76 - ADD : FTP - password save function - FIX : Crypton option added - FIX : smartcard reinit - FIX : netcr fixed - FIX : Multi Ch Recoding Freezing issue. fixed - FIX : Radio Event Recording bug fix - FIX : TNTSAT card update and HD+ AU bug fixed DigiLine 7000 HD 020.04 Viva_020.04 - FIX : Release the CIFS - FIX : CanalSat HD 19.2E(viaccess 3.0 patch) - FIX : TP List Update - FIX : CanalSat 19.2E(viaccess 3.0 patch) - FIX : BIS via2.6 updated. Viva_019.90 - FIX : Astra1E3A TP update - FIX : Event Timer (Daily, Weekly) event record fix. - FIX : Motor bug fix. - FIX : FTP Zombi process delete. Viva_019.80 - FIX : Sky italia NDS update. - FIX : AK4707 INT method changed (Monitor Detect -> SlowBank Detect) - ADD : FTP - password save function - FIX : smartcard reinit killed. fixed - FIX : Multi Ch Recoding Freezing issue. fixed. Labots Jūnijs 29, 2010 - mazais Link to comment Share on other sites More sharing options...
Gincha Jūlijs 5, 2010 Share Jūlijs 5, 2010 Ar šuvumu 20.04 uzmanīgi! Pats mēģināju- satelīta daļa strādā normāli, LatTeleCom virszemes TV kanāli nestrādā, ne FTA, ne Conax, signālu rāda. Atgriezos atpakaļ uz 19.85 http://www.unisat.lv...topic.php?52.30 Pie kam, pēc pāršūšanas atpakaļ uz 19.85, resīveram vairs nebija atmiņā uzstādītie virszemes TV kanāli (iespējams, ka arī satelītu daļā bija kaut kas nojaukts). Palīdzēja iepriekš saglabātais UserData fails. Link to comment Share on other sites More sharing options...
mazais Jūlijs 5, 2010 Share Jūlijs 5, 2010 Man uz 20.04 Lattelecom FTA iet normāli, karti nepārbaudīju. Es pēc jaunā šuvuma uzlikšanas uzreiz nometu iestatījumus uz rūpnīcas iestatījumiem. Pēc tam visu liku no jauna, jo bija izmaiņas sat.antenai. Vecos UserDta nemēģinju. Link to comment Share on other sites More sharing options...
GulbisRG Jūlijs 20, 2010 Share Jūlijs 20, 2010 Kadas atsauksmes? vai aparāts normāli shancē? kads tad ir pedejais softs Viva_020.04??? Vai ar to viss chikinieka? Kā var nomainīt ViasatSportBaltic valodu. Citādi man zviedriski vai lietuviski komentē!!! Link to comment Share on other sites More sharing options...
Gincha Jūlijs 20, 2010 Share Jūlijs 20, 2010 Uz pults AV+, tālāk sapratīsi pats. Link to comment Share on other sites More sharing options...
mazais Jūlijs 23, 2010 Share Jūlijs 23, 2010 DigiLine 7000HD 020.08 Viva_020.08 - FIX : Implement Media highway EPG function - FIX : Canalsat emu and TNTsat smartcard fix - FIX : Release the CIFS - FIX : CanalSat HD 19.2E(viaccess 3.0 patch) - FIX : TP List Update - FIX : CanalSat 19.2E(viaccess 3.0 patch) - FIX : BIS via2.6 updated. Link to comment Share on other sites More sharing options...
mazais Augusts 23, 2010 Share Augusts 23, 2010 DigiLine 7000HD - 020.15 - FIX : mcas lib update/DRECrypt (pirate card) fix - FIX : Fastscan/Diseqc Issue - FIX : DIGITV AU support (Thor_1W) - FIX : improve the ac-3 switching problum issue in HELLO HD channels - FIX : DRECrypt sc fix, included MiniMax AU (AMOS 4W) - FIX : Implement Media highway EPG function - FIX : Canalsat emu and TNTsat smartcard fix - FIX : Release the CIFS - FIX : CanalSat HD 19.2E(viaccess 3.0 patch) - FIX : TP List Update - FIX : CanalSat 19.2E(viaccess 3.0 patch) - FIX : BIS via2.6 updated. Link to comment Share on other sites More sharing options...
budulaajs Septembris 5, 2010 Share Septembris 5, 2010 Mazais ,vai nebūtu tik laipns un nepadalītos ar avotu kur tu ņem (apgeitus PO)!, jo man ir aizdomas ,ka tas ir avots ārzemju forumi kur ir tikai viens cilvēks kurš izliek PO un cik es Redzu viņa vārds te netiek pieminēts,FUI Link to comment Share on other sites More sharing options...
janispauls Septembris 5, 2010 Share Septembris 5, 2010 (labots) Vai no sākuma lasiji topiku,ir taču google,priekš kam tev zināt pianistu baru kas bīda delas ,gribi no viņiem nopirkt,vai pārdot šie ir ir labi nostādijuši šo aparātu http://www.boot.lv/forums/index.php?/topic/122476-digiline-7000-hd-violet-box/ Labots Septembris 5, 2010 - janispauls Link to comment Share on other sites More sharing options...
mazais Septembris 5, 2010 Share Septembris 5, 2010 Es ņemu no krievu foruma :http://westsat.com.ua/index.php Un šajā forumā PO liek lietotājs ar niku: Gints. 1 Link to comment Share on other sites More sharing options...
budulaajs Septembris 6, 2010 Share Septembris 6, 2010 (labots) Tagat sāki laboties un tā turpini pieminot viņa vārdu!un paldies ,ka esi tik saprotoš ,ka cita pūles ir jāciena ! PS (GINTS arī budulaajs) Un PO izlieku (,Mana saite un šur tur) Labots Septembris 6, 2010 - budulaajs Link to comment Share on other sites More sharing options...
budulaajs Septembris 23, 2010 Share Septembris 23, 2010 (labots) DIGILINE 7000HD VVEC020.25 Вышел новый софт DIGILINE 7000HD VVEC020.25 - FIX : Subtitle Menu Issue fix - FIX : mcas lib update/New lib there is an bugfix for viaccess smartcard issue - FIX : mcas lib update/DRECrypt (pirate card) fix - FIX : Fastscan/Diseqc Issue - FIX : DIGITV AU support (Thor_1W) - FIX : improve the ac-3 switching problum issue in HELLO HD channels - FIX : DRECrypt sc fix, included MiniMax AU (AMOS 4W) - FIX : Implement Media highway EPG function - FIX : Canalsat emu and TNTsat smartcard fix - FIX : Release the CIFS - FIX : CanalSat HD 19.2E(viaccess 3.0 patch) - FIX : TP List Update - FIX : CanalSat 19.2E(viaccess 3.0 patch) - FIX : BIS via2.6 updated. Labots Septembris 23, 2010 - Rudiger mazāki burti izskatās labāk Link to comment Share on other sites More sharing options...
GulbisRG Oktobris 5, 2010 Share Oktobris 5, 2010 man velviens tāds jautājums, vai parskanējot tv programmas man pazudīs mans izveidotais favorītu saraksts? Citādi man ka paris nedēļas TV6 nerāda! Link to comment Share on other sites More sharing options...
budulaajs Oktobris 5, 2010 Share Oktobris 5, 2010 man velviens tāds jautājums, vai parskanējot tv programmas man pazudīs mans izveidotais favorītu saraksts? Citādi man ka paris nedēļas TV6 nerāda! Ir varbūtība .ka paliks ,bet es domāju ,ka nobirs FAVORĪTI tieši virszemes kanālos ,bet vari visu iepriekš uz fleškas saglabāt un tad pārskanēt tieši virszemes kanālus un tad zināsim arī mēs visi! Link to comment Share on other sites More sharing options...
GulbisRG Oktobris 5, 2010 Share Oktobris 5, 2010 nu man vairāk intresē sat favorīti, man virzemes nemaz nav pierubīta negribās riskēt, favorītus taisiju 2 dienas Link to comment Share on other sites More sharing options...
budulaajs Oktobris 7, 2010 Share Oktobris 7, 2010 nu man vairāk intresē sat favorīti, man virzemes nemaz nav pierubīta negribās riskēt, favorītus taisiju 2 dienas Es saku saglabā uz fleškas tagadējos parametrus un skanē no jauna un redzēsi nobira vai nē, un ja nobirs vari no fleškas atjaunot savus iepriekšējos parametrus! Link to comment Share on other sites More sharing options...
GulbisRG Oktobris 8, 2010 Share Oktobris 8, 2010 Nu nenobira Favorīti saglabājās. Automāta TV6 atrada, bet melna bilde jo projam. Jameiģina manuali. Nesmu nekad to darijis Hmmmm. Lieta tāda ka manuāli meklējot atrod to TV6 bet viņš pēc noskanēšanas nepievienojas visu kanālu sarakstam. Paliek vecais!!! Link to comment Share on other sites More sharing options...
budulaajs Oktobris 8, 2010 Share Oktobris 8, 2010 Nu nenobira Favorīti saglabājās. Automāta TV6 atrada, bet melna bilde jo projam. Jameiģina manuali. Nesmu nekad to darijis Hmmmm. Lieta tāda ka manuāli meklējot atrod to TV6 bet viņš pēc noskanēšanas nepievienojas visu kanālu sarakstam. Paliek vecais!!! Tev tv6 vajaga uz viasata vai lattelekoma? Link to comment Share on other sites More sharing options...
GulbisRG Oktobris 13, 2010 Share Oktobris 13, 2010 nu man vairāk intresē sat favorīti, man virzemes nemaz nav pierubīta negribās riskēt, favorītus taisiju 2 dienas SAT SAT SAT Sveicināti, Ir neleils jautājums. Lieta tāda ka tek medus 36 grādos un rāda gandrīz visu. HTB+ HTB HD Tricolot bet nav poņas papēc nerāda Poverhnost? Signāl ~80 Quality uz 10% un melna bilde!!! Kur varētu būt vaina? Vainu jāņem trepes un jarāpjās pie antēnas vai arī aparāta configos nav labi? Un vai TV6 rāda kādam uz Digiline 7000HD no stropa??? 2 Link to comment Share on other sites More sharing options...
jacobs Oktobris 13, 2010 Share Oktobris 13, 2010 Cik zinu,tad kompānija Poverhnostj ir praktiski bankrotējusi,kas nav liela bēda,jo visi tās kanāli ir salasāmi citur. TV6 Latvia rāda,ja strops to nodrošina,neatkarīgi no medus aparāta. 1 Link to comment Share on other sites More sharing options...
Exy Oktobris 13, 2010 Share Oktobris 13, 2010 Pēc 3 dienām būs 2 mēneši kā Virsma Plus ir atslēgta no Eutelsat raidītājiem par īres maksas nemaksāšanu un nav nekādu ziņu par viņas turpmāko likteni. 1 Link to comment Share on other sites More sharing options...
budulaajs Oktobris 13, 2010 Share Oktobris 13, 2010 (labots) Un vai TV6 rāda kādam uz Digiline 7000HD no stropa??? Astra 4A, 4.8°E 'TV 6 Эстония' и 'TV 6 Латвия' ушли с 11900V. 'TV 6 Эстония' и 'TV 6 Латвия' появились на 11958H (скандинавский BSS луч), Videoguard, SR 27500, FEC 3/4. Bet tajā transponderā ir tikai Lietuviešu TV6 http://satsattv.info/showpost.php?p=4390&postcount=91 Labots Oktobris 13, 2010 - budulaajs 1 1 Link to comment Share on other sites More sharing options...
MartiniB Oktobris 13, 2010 Share Oktobris 13, 2010 "REGULĒ VĒL .." Link to comment Share on other sites More sharing options...
GulbisRG Oktobris 13, 2010 Share Oktobris 13, 2010 Bet lieta tāda ka veco TV6 no kopējā saraksta izdzēsu. Skanējot 11958H viņu atrod bet TV6 uzrakst ir pelēkā krāsa( kas nozīme ka kanāls jau ir sarakstā) Bet izejot cauri sarakstam tur viņu atrast nevar hmmmm... skāde!!! Link to comment Share on other sites More sharing options...
