Mr.Santīms Ierakstīts Janvāris 15, 2010 Share Ierakstīts Janvāris 15, 2010 Sveiki! Man tātad ir problēma ar Quick Launch, katru reizi slēdzot datoru tas pazūd un nākas likt pasam atpakaļ. Vai ir iespējams šo problēmu novērst? Link to comment Share on other sites More sharing options...
vilksz Janvāris 15, 2010 Share Janvāris 15, 2010 Now that you have Quick Launch on the taskbar, you will need to save your current theme (step 4 at this link). NOTE: If you make any changes to your theme, you will need to save the theme afterwards, or you will lose Quick Launch the next time you restart the computer. If you have a 32-bit Windows 7, then it has been reported that you may need to turn off UAC if Quick Launch is disappearing on you after every restart. NOTE: This is not a problem experienced in the 64-bit Windows 7 though. Pa fikso googlē, neesmu pārbaudījis. Link to comment Share on other sites More sharing options...
Mr.Santīms Janvāris 15, 2010 Author Share Janvāris 15, 2010 Paldies par ātro atbildi! Link to comment Share on other sites More sharing options...
