Žaks Noriss Maijs 18, 2009 Share Maijs 18, 2009 Vai kāds ir pamēģinājis alternatīvo FW no www.wdtvc.com? Čeindžlogs ir pilnīgi nekāds * OSD tweaks* changed now playing view format * added selectable 4, 6, 8 item list view (default=8) (via shell: config_tool -c THUMBNUM=X) * added selectable 4, 8, 12 thumb browse view (default=12) (via shell: config_tool -c LISTNUM=X) * increased font size of title to 32 in thumb view * removed 2 unused binaries * updated build scripts to dynamically generate all version info * sample S00custom-options provided Bet ir interese pamēģināt un nav nekādas intereses nograut WD TV HD aparātu. Link to comment Share on other sites More sharing options...
oika Maijs 18, 2009 Share Maijs 18, 2009 Nez kapēc šādu video negrib korekti atskaņot.Atēls saiet kvadrātos.Varbūt kāds zin iemeslu? Video Format : AVC Format/Info : Advanced Video Codec Format profile : High@L5.1 Format settings, CABAC : Yes Format settings, ReFrames : 13 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1h 30mn Bit rate : 6187 Kbps Nominal bit rate : 6466 Kbps Width : 1920 pixels Height : 1040 pixels Display aspect ratio : 16/9 Frame rate : 23.976 fps Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.135 Writing library : x264 core 54 svn-620M Encoding settings : cabac=1 / ref=10 / deblock=1:-2:-1 / analyse=0x3:0x133 / me=umh / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=2 / nr=0 / decimate=0 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=6466 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio Link to comment Share on other sites More sharing options...
Žaks Noriss Maijs 18, 2009 Share Maijs 18, 2009 Varbūt iemet pilno faila nosaukumu. Var arī uz PM. Link to comment Share on other sites More sharing options...
oika Maijs 18, 2009 Share Maijs 18, 2009 Complete name Ледниковый_ период_2_[tfile.ru]\Poteplenie.Globalnoe.2006.HDTVRip.mkv Format : Matroska File size : 4.38 GiB Duration : 1h 30mn Overall bit rate : 6917 Kbps Encoded date : UTC 2007-02-12 22:00:00 Writing application : mkvmerge v2.0.0 ('After The Rain Has Fallen') built on Jan 13 2007 19:58:56 Writing library : libebml v0.7.7 + libmatroska v0.8.0 Link to comment Share on other sites More sharing options...
Žaks Noriss Maijs 25, 2009 Share Maijs 25, 2009 Tas tev tikai vienam failam gļuks? Uz PC viss normāli griežas? P.S. negribas tādu kluci lejuplādēt un pārbaudīt uz sava. Iznākusi jauna beta FW 1.02.08. Pats pagaidām nogaidīšu, ar betām nav vēlme ņemties, kaut gan čeindžlogs ir daudzsološs -Some characters still missing from Greek font-VC-1 MKVs playback poorly -Audio out of sync during MKV playback -10 Minute FF and REV doesn’t work during MKV playback -Audio clipping issues Link to comment Share on other sites More sharing options...
maurs Jūnijs 4, 2009 Share Jūnijs 4, 2009 Vai šitam WD ir iespējams uzlikt, lai maļ to filmu visu laiku (atkārto)? Link to comment Share on other sites More sharing options...
Mr.Sports Jūnijs 4, 2009 Share Jūnijs 4, 2009 Jā var! Un var arī lai visu sarakstu pēc kārtas atskaņo. Kad atskaņo failu, tad nospied ''opcijas'' un izvēlies nepieciešamo. Link to comment Share on other sites More sharing options...
Explo Jūnijs 7, 2009 Share Jūnijs 7, 2009 lieta tāda, ka pleijeris neatksanjo DTS skaņa formātu, bilde ir, a skaņa nav, piem. mkv tipa failiem, ir kaadi risinaajumi? piem. konvertēšana un ar ko? Link to comment Share on other sites More sharing options...
Žaks Noriss Jūnijs 7, 2009 Share Jūnijs 7, 2009 (labots) Palasies postus uz atpakaļu - ir tāds Popcorn Audio Converter. EDIT: DTS jau atskaņo gan, tikai nav iekšā DTS dekoderis. DTS var dabūt caur optisko uz resīveri. Labots Jūnijs 7, 2009 - Žaks Kustō Link to comment Share on other sites More sharing options...
Explo Jūnijs 7, 2009 Share Jūnijs 7, 2009 tu domā, ar optisko kabeli saslēgt ar resīveri no WD pleijera? Link to comment Share on other sites More sharing options...
osscar Jūnijs 7, 2009 Share Jūnijs 7, 2009 jā, tā dabūsi 5.1 skaņu. Link to comment Share on other sites More sharing options...
Explo Jūnijs 7, 2009 Share Jūnijs 7, 2009 laba ideja, nebuus ar to konvertaaciju jaacakareejaas, ja tieshaam DTS caur to skanees, a kaads tas kabelis izskatās? Link to comment Share on other sites More sharing options...
buffalo Jūnijs 7, 2009 Share Jūnijs 7, 2009 http://akamaipix.crutchfield.com/lifestyle...oslinkPlug.jpeg to vadu eiropaa sauc par optical, bet tiek arii deeveets par toslink... Link to comment Share on other sites More sharing options...
Explo Jūnijs 8, 2009 Share Jūnijs 8, 2009 Tnx, taa arii domaaju ka tas ir tas. hmm...tikai viens bet, WD pleijerim ir audio optiskā izeja, bet resīverim - koksiālā ieeja, tas laikam nav viens un tas pats, ar optisko kabeli tad nesanāks šāds variants, ko savādāk varu izdarīt? Link to comment Share on other sites More sharing options...
Žaks Noriss Jūnijs 8, 2009 Share Jūnijs 8, 2009 Dajoš studijā resīvera modeli. Nav dzirdēts, ka būtu tikai coax ieeja bez nevienas optiskās... Link to comment Share on other sites More sharing options...
Explo Jūnijs 8, 2009 Share Jūnijs 8, 2009 nee nee, man ir maajas kinozāles DVD pleijeris, kas atbalsta DTS, un gribeeju caur to skaņu palaist ar šo optisko kabeli...bet nu laikam nesanaaks cik sarpatu, nav jau nekaadi paarveidotaaji uz koksiālo... Link to comment Share on other sites More sharing options...
mistachuck Jūnijs 8, 2009 Share Jūnijs 8, 2009 ir variants, kas nav tas lētākais prieks: http://www.servo.lv/products.asp?category_id=110073 ārzemēs tāds maksā aptuveni 13 dolāri, tā ka ir viela pārdomām, vai tev tas ir vajadzigs, un cik ļoti. Ja tas ir tikai dēļ 1 filmas, tad labāk nokonvertē un miers. Link to comment Share on other sites More sharing options...
daysleeper Jūnijs 9, 2009 Share Jūnijs 9, 2009 iesācējs visās šajās lietās, bet vaicāšu pēc padoma shēmā, kurā ietilpst arī WD HD TV. Tātad doma ir iegādāties Iiyama monitoru 24 collu, pievienot klāt WD HD TV, varbūt nākotnē varētu būt Lattelecom digitālā televīzija. Vai kādam ir pieredze līdzīgā kombinācijā visu kopā sajūgt? Digitālās televīzijas dekoderis barojas tikai caur HDMI? tas nozīmē, ka vajadzētu monitoram divas HDMI ieejas? Ik pa laikam varētu būt vajadzība pieslēgt arī datoru caur DVI pie monitora, tādēļ monitors nevis televizors klasiskais. Kas notiek ar tv ekrānu, kad WD ir atslēgts? vai man jāceļas slēgt ārā arī monitors? Link to comment Share on other sites More sharing options...
mistachuck Jūnijs 9, 2009 Share Jūnijs 9, 2009 Ja tu grasies tam monitoram klāt jūgt PC, tad WD TV tev sasodīts nav vajadzīgs, jo tā funkcijas pilda dators, kura izpildījums attiecīgajās collās ne ar ko neatšķirsies no WD TV sniegtā. Kas attiecas uz monitora "standby", tad te, visticamāk, monitors rīkosies tieši tāpat, kā LCD TV, proti, pašam WD TV ir "gulēšanas (sleep)" funkcija, savukārt uz monitoru jebkurā gadijumā tiek padots signāls (arī šis "sleep"), tā ka monitors diez vai izslēgsies. Link to comment Share on other sites More sharing options...
GulbisRG Jūnijs 11, 2009 Share Jūnijs 11, 2009 A ko nozīmē tie Modeļi tiem WD HD. Visos mūsu veikalos ir Modelis WDAVP00BE bet WD mājas lapa norāda uz WDAVN00??? Ar ko viņi atšķirās??? Link to comment Share on other sites More sharing options...
reiny Jūnijs 11, 2009 Share Jūnijs 11, 2009 Vai WD HD Media Playerim ir kaut kas tāds, kas nav "Pocpcorn Hour A110" (letāku cenu neskaitot)? Es tā saprotu, ka Pocpcorn atsķirībā no WD atbalsta DTS skaņu + to var pieslēgt pie datora caur LAN. Link to comment Share on other sites More sharing options...
maurs Jūnijs 11, 2009 Share Jūnijs 11, 2009 Vai ir kaut kāds knifs, lai palaistu iso? Uztaisīju iso failiņu no dvd, bet jamais nevar atskaņot Link to comment Share on other sites More sharing options...
mistachuck Jūnijs 12, 2009 Share Jūnijs 12, 2009 (labots) Vai WD HD Media Playerim ir kaut kas tāds, kas nav "Pocpcorn Hour A110" (letāku cenu neskaitot)?Es tā saprotu, ka Pocpcorn atsķirībā no WD atbalsta DTS skaņu + to var pieslēgt pie datora caur LAN. Pašam jau laikam specifikācijas skatīties slinkums? gribi lai citi tavā vietā sagremo un iebāž mutē? Tās ir divas dažādas kategorijas, kā cenā, tā iespējās. kuram ir vajadzīgas specifiskās iespējas, ņem popkornu un tamlīdzīgus (vismaz 30 dažādi paveidi), vai pašu primitīvāko, proti, WD TV, kuram iespējas apgrieztas līdz minimumam. Labots Jūnijs 12, 2009 - mistachuck Link to comment Share on other sites More sharing options...
Žaks Noriss Jūnijs 12, 2009 Share Jūnijs 12, 2009 Vai ir kaut kāds knifs, lai palaistu iso? Uztaisīju iso failiņu no dvd, bet jamais nevar atskaņot Atbalstāmo failu sarakstā .iso nav, bet visas ražotāja firmwāres (1.01.02 līdz 1.02.07) .iso atskaņo bez problēmām. Un bez menu. Bet ja DVD saturs ir pareizi iemānīts iekš .iso, tad nevajadzētu būt aizturēm. Vismaz es neesmu novērojis. Pamēģini vēlreiz .iso saturu pārdzīt uz svaigu .iso, lietojot DVDShrink. P.S. nav info kā uzvedas DVD ar multiangle. Link to comment Share on other sites More sharing options...
GulbisRG Jūnijs 29, 2009 Share Jūnijs 29, 2009 asf. failus arī nespēlē!!! Link to comment Share on other sites More sharing options...
Žaks Noriss Jūnijs 29, 2009 Share Jūnijs 29, 2009 Pieejama WD Beta Firmware 1.02.10 Link to comment Share on other sites More sharing options...
kdda Jūnijs 30, 2009 Share Jūnijs 30, 2009 Vai šo te wd tv ar lan-usb adapteri var pieslēgt pie datora un pēc tam strīmot ar vlc uz tv interneta televīziju? Cerams, ka sapratāt, ko gribēju pateikt. Link to comment Share on other sites More sharing options...
IVARS Jūnijs 30, 2009 Share Jūnijs 30, 2009 Es arī īsti nesaprotu vai WD atbalsta DTS vai nē....it kā, ja caur HDMI vai optisko pieslēdz resīverim... vai viņš tikai pārveido uz stereo skaņu? Link to comment Share on other sites More sharing options...
Prime Jūnijs 30, 2009 Share Jūnijs 30, 2009 Caur optiku būtu labākais varients Link to comment Share on other sites More sharing options...
mistachuck Jūnijs 30, 2009 Share Jūnijs 30, 2009 Vai šo te wd tv ar lan-usb adapteri var pieslēgt pie datora un pēc tam strīmot ar vlc uz tv interneta televīziju? Cerams, ka sapratāt, ko gribēju pateikt. NĒ! Kautkādi entuziasti, iespējams, ir mēģinājuši to darīt. Izdevies vai neizdevies, īsti neatceros, bet jebkurā gadijumā "pistons" garantēts. Es arī īsti nesaprotu vai WD atbalsta DTS vai nē....it kā, ja caur HDMI vai optisko pieslēdz resīverim...vai viņš tikai pārveido uz stereo skaņu? WD mazajam aparātam nav DTS dekodera, tam ir ierobežotas (bet gana plašas) audio formātu atskaņošanas iespējas. Taču caur optiku (iespējams arī caur L/R audio) padodot uz resīveri atskaņos jebkuru audiofailu, kuru attiecīgais resīvers spēj dekodēt, tai skaitā DTS u.c. Ja televizoram ir attiecīgie audio kodeki (tādi gan ir retums), tad var iztikt bez resīvera. Link to comment Share on other sites More sharing options...
Guest Jūnijs 30, 2009 Share Jūnijs 30, 2009 Pieejama WD Beta Firmware 1.02.10Paldies. Link to comment Share on other sites More sharing options...
IVARS Jūnijs 30, 2009 Share Jūnijs 30, 2009 NĒ!Kautkādi entuziasti, iespējams, ir mēģinājuši to darīt. Izdevies vai neizdevies, īsti neatceros, bet jebkurā gadijumā "pistons" garantēts. WD mazajam aparātam nav DTS dekodera, tam ir ierobežotas (bet gana plašas) audio formātu atskaņošanas iespējas. Taču caur optiku (iespējams arī caur L/R audio) padodot uz resīveri atskaņos jebkuru audiofailu, kuru attiecīgais resīvers spēj dekodēt, tai skaitā DTS u.c. Ja televizoram ir attiecīgie audio kodeki (tādi gan ir retums), tad var iztikt bez resīvera. ja spēj dekodēt DTS, tad tas nozīmē, ka, ja filma būs ieskaņota 6 kanālos, tad arī skanēs 6 kanāli? it kā man skanēja, kad WD bija ar HDMI vadu pieslēgts pie TV un TV ar optisko savienots ar resīveri....vienīgi nezinu īsti vai skaņa bija stereo vai Dolby Digital 5.1. Vai labāk vienot WD uzreiz pie resīvera un tikai ar HDMI vadu? Vai ir liela atšķirība starp HDMI 1.2 un 1.3? Link to comment Share on other sites More sharing options...
mistachuck Jūnijs 30, 2009 Share Jūnijs 30, 2009 (labots) nav man patreiz tādu tehnisku iespēju noskaidrot tavus sarežģītos savienojumus. Centīšos izteikties, lai durakam ir skaidrs - tas WD TV patiesībā neko nekonvertē (domāts audio) viņš pa tiešo padod signālu, kā stāv, uz tavu ierīci, lai tas būtu TV vai resīvers. Jebkurā gadijumā ar audio konvertāciju nodarbojas tālākā ierīce - TV vai resīvers. Ja TV atpazīst DTS un spēj to padot "pass trough" uz resīvri, tad jā, būs resīverim tik skaņas celiņu, cik tavs TV spēs padot tālāk. Lai būtu drošs, ka tiek izmantoti visi celiņi, labāk savienot pa taisno WD TV ar resīveri caur S/PDIF (HDMI vairumam resīveru "pass trough/converting" notiek tikai video signālam, audio netiek padots). Kā ir tev, pašam labāk jāzin, kā arī ne visām filmām ir 5.1 skaņa. Labots Jūnijs 30, 2009 - mistachuck Link to comment Share on other sites More sharing options...
Žaks Noriss Augusts 10, 2009 Share Augusts 10, 2009 Varētu būt, ka drīzumā būs klāt WD TV 2! http://www.wdtvc.com/2009/08/04/wdtv2-prototype-spotted/ Link to comment Share on other sites More sharing options...
boto Augusts 10, 2009 Share Augusts 10, 2009 Interesanti, Sigmas čips tas pats vecais? Link to comment Share on other sites More sharing options...
Žaks Noriss Augusts 10, 2009 Share Augusts 10, 2009 Čips droši vien vecais, jo nav nekas uz korpusa minēts par Dolby Digital TrueHD vai citiem superformātiem. Pēc aizmugures spriežot video nāk ārā pa HDMI, bet vietas taupīšanas dēļ nav analogo video izeju. Bet ir iespēja piespraust adapteri (labajā pusē blakus LAN). Izejas uz adapteri izskatās ka ir gan kompozītās gan komponentās. Link to comment Share on other sites More sharing options...
Žaks Noriss Augusts 18, 2009 Share Augusts 18, 2009 Reku, boot.lv pirmajā lapā rēgojas oficiāls info par jaunajiem WD TV dampjiem. Neko nekomentēšu par tiem, bet par WD attieksmi vispār. Sūkā! Daudzu zemju pilsoņi jau riktīgu brēku ceļ augšā, ka FW esošajam nav piedzīta līdz vajadzīgajam līmenim, a WD izlaiž jaunus modeļs. Es arī neesmu pārāk apmierināts ar esošo kārtību un ja būtu tagad jāiegādājas, tad meklētu alternatīvu pie citiem ražotājiem. Diemžēl tādas ir šābrīža izjūtas. P.S. WD TV vecais aparāts nav slikts, tikai pilns ar bugiem, kurus WD nejēdz sakārtot. Link to comment Share on other sites More sharing options...
Žaks Noriss Augusts 24, 2009 Share Augusts 24, 2009 Info, ko izlobīju no ārzemju klaču lapām par WD TV jaunajiem modeļiem. WD TV Mini Media Player Šis būs SD pleijeris ar komponento un kompozīto izeju (vadi iekļauti), bez HDMI. Cena drusku zem 100$, jeb ap 55Ls. Kit ContentsHD Media Player Compact remote with batteries Composite AV cable Component AV cable AC adapter Quick Install Guide Compatibility AAC, MP3, JPEG, USB 2.0, Energy Star, Real Media Media Formats AVI (Xvid, MPEG1/2/4), MPG/MPEG, VOB, MP4/MOV (MPEG4), RM or RMVB 8/9/10 JPEG, GIF, TIFF, BMP, PNG MP3, WAV/PCM/LPCM, WMA, AAC, FLAC, MKA, OGG, Real Audio, APE Playlist – PLS, M3U, WPL Subtitle – SRT, SSA, SUB, SMI - RMVB supports up to 1024x576x24 or 800x600x30 compressed video resolution - MPEG1/2/4 supports up to D1 resolution (720x480 in NTSC, 720x576 in PAL) - MPEG2 ML/MP conforming to ISO-13818 - MPEG1 ML/MP conforming to ISO-11172 - A audio receiver is required for multi-channel surround sound via digital optical output. For details, please refer to the user manual. Product Dimensions Height 21x91x91 mm (HxWxD) Weight 113g WD Live TV Media Player Pilna funkcionalitāte (1080p), HDMI, tīkls. Kompozītā un komponentā caur adapteri. Par DTS downmix un DVD un BD menu atbalstu vēl info nav pieejama. Cena ap 150 Eur, jeb 105Ls. -Play Full HD 1080p video, music and photos on your HD TV-Supports widest variety of file formats and devices -Network capable for easy access to the newest content from PCs, network drives, internet favorites Kit Contents -Media Player -Compact remote with batteries -Composite AV cable -Component AV cable -AC adapter -Quick Install Guide Compatibility HDMI, Full HD (1080p), AAC, MP3, JPEG, USB 2.0, H.264, SimplayHD™, Energy Star®, Dolby Digital, DTS, DLNA, Bonjour, AVCHD, Windows Vista Media Formats AVI (Xvid, AVC, MPEG1/2/4), MPG/MPEG, MKV (h.264, x.264, AVC, MPEG1/2/4, VC-1), TS/TP/M2T (MPEG1/2/4, AVC, VC-1) MP4/MOV (MPEG4, h.264), M2TS, WMV9 JPEG, GIF, TIFF, BMP, PNG MP3, WAV/PCM/LPCM, WMA, AAC, FLAC, MKA, AIF/AIFF, OGG, Dolby Digital, DTS Playlist – PLS, M3U, WPL Subtitle – SRT, ASS, SSA, SUB, SMI MPEG2 MP@HL up to 1920x1080p24, 1920x1080i30, or 1280x720p60 resolution. MPEG4.2 ASP@L5 up to 1280x720p30 resolution and no support for global motion compensation. WMV9/VC-1 MP@HL up to 1280x720p60 or 1920x1080p24 resolution. VC-1 AP@L3 up to 1920x1080i30, 1920x1080p24, or 1280x720p60 resolution. H.264 BP@L3 up to 720x480p30 or 720x576p25 resolution. H.264 MP@4.1 and HP@4.1 up to 1920x1080p24, 1920x1080i30, or 1280x720p60 resolution. An audio receiver is required for multi-channel surround sound digital output. Compressed RGB JPEG formats only and progressive JPEG up to 2048x2048. Link to comment Share on other sites More sharing options...
Žaks Noriss Augusts 24, 2009 Share Augusts 24, 2009 Manuprāt zemā cena vispār bija prakstiski vienīgais WD TV trumpis starp 1080p veklošajām iekārtām. A tagad par sotaku vai vairāk - diez vai kāds pirks. Šādā gadījumā Popkorns izskatās labā cenā un pievilcīgāks. Link to comment Share on other sites More sharing options...
Žaks Noriss Augusts 24, 2009 Share Augusts 24, 2009 Esi pats lietojis? Redzējis? Turējis rokās? Link to comment Share on other sites More sharing options...
